chad551
- January 31, 2007
- St.Louis, MO
- 2002 Explorer Sport Trac
I have a small leak at the location where the T-case bolts to the tranny. I know there is a gasket between them. Could there be anything else causing this leak? (tranny seals, t-case seal, etc)
It all started driving home from Moab, and the bolts somehow where a little loose, (not very much) but I was able to crank on them and get almost a 1/4 turn tighter.
It does not seem to leak very bad on short drives, but when a take long drive over 100 miles straight it leaks worse.
Anyone have any ideas? How hard is it to remove the t-case and replace the gasket?
