BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
I want to drain out 1-2 quarts of transmission fluid, and replace it with new fluid. However, I do not want to drop the transmission pan. And, I do not own an extraction pump. I believe my best option is to disconnect one of the flexible rubber hoses going to the transmission cooler (in front of the radiator). I have two questions: (1) Without running the engine, and with the hose disconnected, will I be able to get 1-2 quarts to come out? (2) Will draining fluid from this hose cause any problems such as air locks, etc? After draining 1-2 quarts, I plan to add 1-2 quarts of new fluid before starting the engine.
