gunnerbob
- April 20, 2002
- Albuquerque, NM
- '94
I'm planning on doing a compelte flush of ATF on my 94 4WD. I followed the cooler lines from the transmission to the front, and the line which is closest to the pan goes to the top of the driver's side of the radiator. Another line exits the bottom of the radiator, then goes to the driver's side of what appears to be an external trans cooler mounted in front of the radiator. Another line exits the passenger side of this cooler and back to the transmission, entering above the first line.
Here are my questions:
1) Does anyone know which way the fluid goes, i.e. radiator then cooler or cooler then radiator?
2) Could I connect an extra length of line to the existing line between the transmission and the cooler, so that the old fluid is forced out through the cooler, and new fluid is sucked from a bucket through the extra line back to the transmission when the engine is running?
3) Is this idea crazy?
Bob
Bob
