freakaftr8
- May 23, 2005
- Folsom, CA
- 95 Sport
Hey guys, im new here, and I got a problem, I bought this 95 Explorer Sport automatic electronic overdrive and It doesn't have reverse, if you put it in, when cold and you rev the motor, it will slowly move, when hot, barely, unless you rev the motor to like 4000 rpm or more, then the OD light flashes at me and if im lucky the truck will slowly inch it's way backward in surges. I can drive it around all day in forward, no problems and OD works great, I could drive it a hundred miles a day. The truck does have 171,000 miles on it, but im not sure if there might be a seal failure here or a solenoid? It just seems that the trans works so well in forward gears to have burnt up clutches, any input would be greatly appreciated. And has anyone else ever had this prob? Thanks!
