spitfiresk822
- October 22, 2007
- Rockville, MD
- 98 XLT
Alright, well today I finally got around to dropping my trans pan to install a B and M drain plug so I can finally install my trans temp gauge. Dropped the pan, changed the filter, and went to drill my hole. Well for some reason when the drill bit finally got through, it grabbed and tore the pan a little. So the hole was just a little bit bigger than a 1/2 inch but wasn't a perfect circle. To make a long story short, filed it a little, got the drain plug in, and was hoping that the plastic o ring type thing that came with the drain plug would seal it, I was wrong. So before hunting for a new trans pan, I decided to try some JB weld on just the bolt part of the drain plug and said screw the nut.
Does anybody know:
1. where I can get a new drain pan, stock or something with a drain plug?
2. do u thing the JB will hold up to tranny temps and pressure, especially without the nut?
Any help would be appreciated as my X is currently out of commision, I'm waiting for the JB to dry to give it a shot.
Thanks again
Does anybody know:
Thanks again
