Trans Problems | Ford Explorer Forums - Serious Explorations
Trans Problems
zrxsix3rz
Peoria, Illinois
1997 Xploder
I am getting ready to purchase another explorer, do not know the exact year but its a 98 and up telling by the back hatch and bumpers, its a XLS and it has the 4.0 SOHC with 130000 miles or so on it!
Well the owner of this explorer is telling me that the truck will shift just fine 1st to 2nd but will skip 3rd and go into OD, also the trans will not shift down gears... I don't know if there is a 4th gear or not/what kind of trans it is, nor do I know if I could just shift using low and 2nd options on the column
any input will be appreciated Thanks
Any codes?
Any codes?
They said there is a code that pops up when it comes time to shift into that 3rd gear, i will be looking at it this Saturday and I will ask to scan it with my scanner to see if anything pops up
Off topic but i might also get it for cheaper for doing work to her s10... a guy didnt tighten down the wheel right or something, needless to say, the tire came off and bad things happened
Thanks for the reply
Sounds like SSC could be either stuck or jammed or both. Just a suggestion. Has anybody poked at the valve body recently?
Not that I am aware of, my guess would be no
