utmustang88
- November 18, 2002
- Toledo, OH
- 1996 EB
Trans removal in progress 3-6-04; Done 3-11-04
I put the explorer up on stands and started taking eveything apart b/c of a little leak that I think is the seal in the bell housing. I consider myself a Avg-level mechanic working at a nice relaxed pace; but those darn RUSTED Ohio salt winter-ed header bolts.
I didn't really see on the board people posted times on how long it took them to do things, so i thought i might chime in here and let people know how/what whe bolts are all rusty. Mind you this project is working on a car that has been through 8years of Ohio salt and snow. I have a heated garage with jackstands and a stock explorer.
3Hrs
1. prep the explorer on stands and look over task at hand.
3. get all tools ready.
4. take a lunch break.
5. remove the drive axles front and rear(nuts were rusted).
3.5Hrs
1. disconected all wiring attached to tranny and T-case.
2. drained T-case fluid.
3. broke loose the T-case bolts.
4. tried to get header bolts loose for the Y-pipe
6Hrs approx
1.Removed Transfer Case(1hr..not too bad..rested it on my legs and then wiggled off..make sure to have drain pan for tranny fluid)
*make sure to cover all shafts and machined parts with paper towels, plastic bags, or somehting.....you don't want any foreign debris getting in there*
2.Removed Starter(1Hr..PITA with 4x4 real real tight space..must have patience..i have small hands too)
3.Removed T/C-flexplate bolts
30mins..not too bad)
4.Removed Drain Pan from tranny
45mins) and didn't find any metal shavings in bottom...just nice red fluid
. I put the pan back up and secured it down with 2 bolts so no dust or dirt would get up there.
5.Moved the car off ramps and put on jackstands and removed front tires
30mins)
6.Tried those header bolts again...no luck....
45mins)
7.Thinking time, pondering time, or as some people call it hitting a wrench against something b.c it makes you feel better time(we needed a new light anyways
)(1.5hrs)
4hrs
1.got the header flange cherry red and the 4 header bolts slid right out....wow amazing...i guess we learn by trial and error.
2.removed tranny crossmember and supported tranny with jack. removed tranny 2in thick rubber stopper.
3.removed heat shield from cat to clear tranny
4.removed y-pipe....YEAAAAAAA!
5.disconnected cooler lines
6.removed tranny to engine bolts(this one took some time)
7.i had tranny supported right behind the bellhousing and it balanced really well. i actually removed the tranny by myself b/c dad went to bed. be very careful on this step....tranny weighs in the approx of 200lbs.
That's it....now i have to figure out what the real problem is! also make sure to be very clean and plug all holes in tranny b/c dirt doesn't mix well with fine machined parts.
3Hrs
3.5Hrs
6Hrs approx
4hrs
