paul444e
- July 31, 2015
- Etna maine
- 2002 explorer
To start off thanks to all that reply your the hart of all that keeps sites like this going. 2002 explorer with 5R55W transmission. Started out a bad leak,thought it was a torque converter seal,till I was pulling transmission and saw the overdrive servo cover and snap ring hanging out. Well pulled off torque converter seal looked good so the leak is obviously the servo. Took out servo piston, worn on one side bore doesn't look worn. I called a local trans shop and they said this is a common problem with fords. He said with wear it becomes a over pressure issue and will need to be rebuilt. If I fix the servo it will fail soon after.He can do it out of truck 1500 parts and labor with servo bore repair. And I still cant afford it.Can any one help with a book on this trans. Maybe some theory of operations, where is the pressure control valve,need some help here looking to fix as cheap as possible with out a total rebuild. thanks to all found this if it helps anyone else https://www.youtube.com/watch?v=WNugELqS2qI
