Trans Temp Gauge
SSR
Chicago Ridge, IL
94 XLT
Anyone have any idea on a good spot to mount a trans temp gauge, a have a 2 5/8" gauge w/ mounting up.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
wabbit
Western Colorado
the white one...
Mounting my trans temp gauge was tricky...
I really had to think on how to do it. The only available place was on the dash skirt below the steering column. That would have been less than ideal because the taper of the panel is toward the floor making the gauge difficult to monitor.
Here's what I did...
Remove the push button FWD switch and relocate it to the dash skirt. I put it on the right hand side as far up as it would go and have clearance behind the panel. The wires to the FWD switch were just long enough to reach to the new mounting location.
Where the FWD switch used to be, make a panel to fit that hole. Make it out of metal or plastic. Cut a circle in the panel to accept the gauge. Mount the gauge to the panel and the panel in the hole. TaDa!! excellent mounting location for a trans temp gauge, and... custom location for FWD switch.
Another little hint- Offset the gauge hole to one side to allow for possible mounting of a toggle switch beside the gauge.
Hope this helps...
wabbit
Western Colorado
the white one...
no pics at this time...
I will go ahead and take a few and see about getting them posted.
Another possible option with less modification would be to check into AutoMeter Gauge Pods that mount along the door/windshield frame. At the time I did my install, they were not available for 91-94 Explorers.
SSR
Chicago Ridge, IL
94 XLT
That sounds pretty cool, some pictures would be great. I don't want to use a gauge pod is because I am planning on buying a supercharger, and I am going to put boost and fuel pressure in the pod.
B trans temp gauge sensor mounting help Modified Explorations 11
B trans temp gauge? Modified Explorations 14
P Trans Temp gauge install on a 1994 explorer. Modified Explorations 28
V Autometer Oil Pressure and Trans Temp installed in center console! Modified Explorations 14
S Trans temp sender location?? Modified Explorations 1
M Swapped Manual For A Auto Trans Now I Have Troubles Modified Explorations 6
E Trans Shifter for v8 swap Modified Explorations 5
G KKM kit on '94 Sport, 4X2, Manual trans? Modified Explorations 2
B trans cooling fan purchase and help Modified Explorations 3
R Got Engine Need Trans. Modified Explorations 1
M trans swap Modified Explorations 2
L Secondary trans cooler installed Modified Explorations 14
D A/T trans cooler mounting location? Modified Explorations 9
D 1996 trans cooler Modified Explorations 0
M 00EX 5.0 & trans into a 98 sport Modified Explorations 0
L Aux. Trans filter & warranty? Modified Explorations 1
B $853 manual trans flywheel??? Modified Explorations 10
R Trans filter pics Modified Explorations 1
J Axles/transfer/trans questions Modified Explorations 1
B six speed man trans help Modified Explorations 4
C Motor/trans mods to '91 XLT Modified Explorations 8
C B&M trans controller ? Modified Explorations 5
A Trans cooler upgrade Modified Explorations 22
N Trans Cooler Modified Explorations 1
B trans go shift kit Modified Explorations 4
S ford 4.0 trans failure? AA wants comments Modified Explorations 255
S trans problems (A4LD) Modified Explorations 7
P Re-routing diff, tranny, trans etc lines Modified Explorations 16
S Trans mods (a4LD) Modified Explorations 12
S A4LD Trans mod ideas, ?'s Modified Explorations 12
I ATG Interceptor Trans control Modified Explorations 0
S Trans cooler to steering cooler Modified Explorations 5
K low engine temp Modified Explorations 0
W need help wiring a water temp guage Modified Explorations 3
L Temp. in rear view mirrow Modified Explorations 1
0 Wiring up tranny temp gauge Modified Explorations 2
Trckmagik Trckmagik's Tranny temp guage install..Pics Modified Explorations 28
4 Tranny temp guage Modified Explorations 0
W E-fan temp probe question Modified Explorations 2
H Installing Aftermarket Coolant Temp. Gauge Modified Explorations 2
B How acurate would oil temp sender be connected to the presure port Modified Explorations 1
B overhead console--temp sensor Modified Explorations 5
R OVERHEAD CONSOLE temp stuck Modified Explorations 8
Dre Tranny fluid temp gauge? Modified Explorations 14
R Underhood temp test results Modified Explorations 9
B Tranny temp sender in pan?? Modified Explorations 10
W Temp' Guage Modified Explorations 2
J Transmission Operating Temp Modified Explorations 1
H First Gen Gauge Pods Modified Explorations 18
S Gauge backlight color Modified Explorations 0
Similar threads
