DeadAWD
- September 17, 2009
- Duvall, WA
- '96 Ford Explorer XLT AWD
Hi again,
As I've mentioned my 1996 AWD is now resurrected and I'm happy to have wheels again. I've been driving it for 2 weeks and all has been fine. Today or tomorrow I'm going to flush out the Mercon and put in Mobil 1 synthetic ATF (I've already purchased it). And I'm saving up my money to replace the ATF in the trans with synthetic too.
But my post is about my old TC case. I want to tear into it. I want to weld it up in a way so that the power goes straight to the back wheels and nothing to the front, effectively making the car 2WD (for summer use and especially for towing). Remove the chain in the transfer case and the front drive shaft too.
Based on common sense and knowledge of planetary gears I think I would have to lock up the viscous coupling and weld the planetary gears to the planetary gear cage. Then I could reassemble the TC without the chain. Voila: 2WD at the rear wheels. I think.
Am I right in thinking that I would have to lock up the planetary gears and the viscous coupling? Or is it something else?
Here is what I was thinking would be limitations.
1. Welding hardened metal parts changes the strength properties and weakens them significantly.
2. I might need to add more AFT to the transfer case.
Does anyone have a locked up viscous coupling from a 4404? Not one that is shot and makes the heinous truck-shaking thumping. But one that is locked up and makes the front wheels chirp a little upon turning. That might be the easiest way to lock up the viscous coupling (instead of welding). Then I might only have to weld up one other thing.
Maybe I want a bolt-in 2WD TC case for summer and towing. Then I will reinstall my AWD case for winter (which is great for snow, rain, gravel, etc).
Anyone have any ideas????
Cheers,
Dave
Cheers,
Dave
