sn8kbit
- January 25, 2004
- music frickin city
- 96 Explorer Sport
I have a 96 sport with manual transmission, 4 wheel drive.
The transmission just locked up in 4th (knew it was coming) and I have a rebuilt replacement on the way. While there, I'll be installing a new clutch assembly, slave cylinder, ect.
Prior to the tranny pooping out on me, the transfer case was fairly noisy (I'm assuming chain). Obviously, it's the 1354 unit electric shift, similar to just about all except AWD, 91 and up. Are there differences between 1st gen t-cases and mine? I've found replacements (used, warranty) ranging between 40-129 dollars. Some from Rangers (99) and some from first gen Ex's. Shift motor in mine is fine (knock on wood) so other than maybe a wiring plug difference, are these t-cases able to swap out? I could rebuild it, but I'm looking to assemble it straight out, and simply swap new in for old.
Searched for quite a bit, did't see anything regarding this.
Thanks,
Steve
Thanks,
Steve
