    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
Transfer case fluid 97 4.0 OHV 5R55E
Daymon Powell
WILMINGTON N.C.
1997 FORD EXPLORER XLT
What is best tx. Case fluid currently using dex/ mercon. Considering. Valvoline SYN. TCF any input much appreciated.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
mercon III is the best fluid for your t case
Do NOT use mercon V
I do not run full synthetic atf in these cases, just Mercon III and change it yearly or bi yearly
christopherjost
1997 Mercury Mountaineer
Best bet is Mercon LV. As Fourten mentioned, do NOT use Mercon V in transfer cases.
96eb96
Albany, NY
96 EB V6 OHV 4WD
Like others said...
Either:
  1. Plain Mercon (not V!!!). This is something you would buy in Walmart, it would say Merc/Dex compatible fluid. Least Expensive.
  2. Mercon LV (Superceded by Ford from the original Mercon Recommendation. Currently Recommended by Ford for our transfer cases). Ford does not license plain Mercon anymore.
  3. Valvoline Transfer Case Fluid (which is probably their Synthetic Trans fluid in a different bottle).
Desert_AIP
1998 Explorer XLT 4WD
I was just researching this.
I understand the Ford replacement for Mercon is XL-12 (bottle marked as "Transfer Case Fluid").
I'm having trouble finding actual Motorcraft XL-12/Transfer Case Fluid.
The Valvoline synthetic TCF states it's XL-12 compatible.
96eb96
Albany, NY
96 EB V6 OHV 4WD
XL-12 is not sold by Ford anymore. There may be a few bottles of NOS somewhere. If the dealer puts XL-12 in their system Mercon LV comes up. Could be LV was enhanced for transfer case use. The VV product is compatible with XL-12, as much as a $3 bottle of regular Mercon is compatible with the original spec.
Desert_AIP
Thanks for the clarification. No wonder I couldn't find the XL-12 :)
Daymon Powell
WILMINGTON N.C.
Like others said...
Either:
Like others said...
Either:
Daymon Powell
WILMINGTON N.C.
Like others said...
Either:
I knew not to put Merc.V in tx.case,but new info. on Merc.LV. Wally doesn't sell reg.dex III in qts. anymore so last time I used the high mi.,no problems .This time I will use the Merc.LV
Thanks for all the info. DMP
96eb96
Albany, NY
96 EB V6 OHV 4WD
This looks like good stuff. Specifically for Dex/Merc:
Advance auto has LV for $7.99. Either would probably be fine.
Falcon_LS
Kuwait
'99 Explorer Eddie Bauer
Since it calls for regular Mercon/Dexron III, I've been running a TES-295 approved fluid.
DILLARD000
Location
Earth
USA
2001 Ford ExST
Last couple of years for original 1354 TransferCase on this 2001 Ford ExST V6~4.0L~SOHC, been using
Valvoline Dex\Merc\MerconLV~FullSyn ATF (1qt or 5qt bottle) from WalMart.
Couple of quarts left in a 5qt bottle on garage shelf now, sharpy marked "For 2001 ExST TransferCase ONLY".
TC seems happy running+shifting 2WHi~4WHi~4WLo without leaks or operating issue.
Did have to replace 4x4 control module & shift motor a couple of years ago, but original TC itself still running good.
To be clear,
use "Dex\Merc\Mercon\MerconLV" compatible ATF in the 1354 TransferCase,
and "MerconV" compatible ATF in the 5r55e Transmission,
do NOT mix these up.
Hope this helps.
D
96eb96
Albany, NY
96 EB V6 OHV 4WD
To be clear,
Hope this helps.
D
That is likely what goes in their Transfer Case Fluid bottle, for a few bucks more.
TC is usually neglected. The clutch creates plenty of heat, and on trucks without 2wd mode(e.g. non 95-96) it is always on. I'm sure the chain does too. I know also some of these cases fail because the case ovals out, I don't know if fluid can play a role in that but according to one trans builder, he believes so.
Probably should have a 30-60K OCI. If used in Low often, or towing probably closer to 30k. It is real easy to change on these trucks too. Under $20, maybe even under $10 if you can find a basic dex/merc.
Desert_AIP
Sidebar question:
Since Power Steering is also specced for Mercon, I assume the replacement is the Mercon LV.
ETA: Found this other thread with a service bulletin referenced.
So looks like I can use Mercon V in both the transmission and power steering, but still need LV in the transfer case
Power Steering Fluid
SB 07-1-7
01/22/07
MERCON(R) ATF REPLACED BY MERCON(R) V AS A
SERVICE FLUID FOR SOME POWER STEERING
SYSTEMS
FORD:
1996-2007 E-Series, Explorer, Ranger
96eb96
Albany, NY
96 EB V6 OHV 4WD
Sidebar question:
SB 07-1-7
01/22/07
SYSTEMS
FORD:
PS system does not have any clutches so mercon V is the right fluid.
SparkyF250
Freeport, OH
2005 Explorer XLT
Don't use Mercon V use either Ford XL-12 or Valvoline Transfer Case fluid is what I use in all my vehicles. 91 F350, 93 F150, 00 F350, 05 Explorer and an 05 F250. Dex/Merc and LV will work too I just use stuff designed for T-cases personally.
Valvoline Multi-Vehicle (TCF) Conventional Transfer Case Fluid 1 QT
Genuine Ford Fluid XL-12 Transfer Case Fluid
96eb96
Albany, NY
96 EB V6 OHV 4WD
Too bad it is discontinued by Ford. It is superseded with Mercon LV. If anyone went to the dealer and got a TC service, they would do a fill with Mercon LV.
