prayforsurf0
- April 7, 2015
- Montauk NY
- 1998 Ford Explorer XLT
I changed my transfer case fluid today and replaced with motorcraft transfer case fluid because I've never addressed the t-case and wanted to make sure it was filled properly with good fluid. To my surprise the old stuff looked surprising healthy.
The change was simple and seamless. Afterwards I got in the truck, started it, and switched from "Auto" to "4x4 High" to "Low".
The light on the dash indicated that I was changing to high 4x4 then low pretty easily. But when I tried to switched back to high from low the light on the dash continued to illuminate "low". I switched back to low then back to high then auto. Eventually the light indicated i was no longer in 4x4 and I assumed I was back into auto.
Later i came to the car and heard a small clicking from the 4x4 switch a few times. taking it for a drive felt very much like 4x4 drive was still engaged even though the light didn't illuminate on the dash indicating so. Getting up to 30 MPH the car wouldn't come out of 2nd gear. I then noticed the o/d light flashing.
I pressed the od button and it seemed to stick.
I drove home right away. I turned the car off and on and in and out of 4x4 high. The dash light was quick to respond to my switch but the car felt the same (4x4 engaged).
Then my heart really sank. I turned the car on again, put it in gear but none of the drive gears engaged ! No forward or reverse, and when I tried to put it back in park t made a sort of grinding noise !!! Ahh !
I turned the car off in neutral and back on and the gears began to engage again and I was able to get it in park without the grinding noise.
Then I ran straight to my computer to write the story here. What the hell did I do ?!
