Transfer Case Fluid | Ford Explorer Forums - Serious Explorations
Transfer Case Fluid
Tyleryac
NJ
2005 Ford Explorer XLT
Can I use Mercon V fluid in my transfer case?
I ready refrenced previous threads however it wasn't clear.
According to my Haynes Manual, no, use plain "Mercon ATF" for the Transfer Case. Mercon V is for the transmissions. The Transfer Case holds 1.5 Quarts.
Ok, thanks!
You should only use Mercon V in the transfer case. Mercon ATF has been replaced by Mercon V
My 2002 e/b specifies Mercon for the transfer case so just today I flushed it and refilled with Mercon V..
John
I went to my local P&A NAPA parts store and got two quarts of Motorcraft "Transfercase Fluid"
