- February 2, 2006
- North East Arkansas
- 2012 F150 4x4
Well, I’ve spent all morning poking around under the front end.
I bought a new u joint for the other end. (this one has a grease fitting) Got that installed and put the d shaft back in. Test drive revealed the same noise.
Jacked it up, put on four jack stands, two under the rear axle tube to have weight on the suspension, two on the front jacking horns on the lower A arms. Started it, put in 4hi and gave it some gas. There is definitely some noise there, but the A arms are not fully loaded and drooping down making the CV angle pretty steep, so the noise could be those, it seemed like it was coming from the front diff. There isn’t anyone to help me to allow me to check things out while its moving. Cruise doesn’t work with no load either.
Loosened the bolts that hang the diff and the bracket on the rear of the diff that bolts to the frame. The bracket bushings are just about shot, this could be transmitting the noise through the frame, but I would think It would do so with no DS since the front diff spins anyway.
Tightened everything back up, checked to see if the diff was touching any frame or other brackets, saw nothing.
One more road test, same noise as before, but at about 35, put into 4 hi. The noise stopped as soon as the case engaged. Kick it out of 4hi and the noise comes back but louder. If I pull over and stop, then start again, the noise is there but not as loud.
After all of this, I suspect that maybe the front diff gear set is worn in on the acceleration side of the gears, not as much on the coast side. With the driveshaft installed, the rotating mass puts a load on the gears in the opposite way than they are used to since the AWD was always pulling, now the tires are pushing. Maybe when I cleaned the diff, it made this worse?
Secondly, maybe the worn out busing on the bracket that bolts right to the diff is transmitting the noise from the differential to the frame and then to the cab. I can definitely feel a vibration on the floorboard. But the question is how does this go away when in 4 hi?
My last guess is that the driveshaft needs to be a double cardian. But if the sound goes away when in 4hi, then that couldn't be it right?
Front diff joint
From passenger side looking out- rear joint
From drivers side looking in- rear joint
Front diff joint
