transfer case problems | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
swvadovec
Richlands, VA
2000 Explorer XLS
My t case will shift from high to low. But the front axle wont engage. Ive replaced the tod relay, the gem, and I even have another tcase. ive hooked the other tcase up with it on the ground, but, I can hold the front yoke while turning the rear one. Ive checked fuses and everything. what could be the problem? tia
Possibly the clutch pack inside the t case.
I thought that was it on my tcase on the truck. But the one i have off the truck is good. Shouldnt the clutches lock up on it with it off the truck. I also checked the voltage of the brown wire at the tcase. Its .5ish in high and 4.2ish in 4lo. Shouldnt it be 12vdc
You'll have to check with somebody who knows but I thing the voltage for high is 5volts.
And the clutch should lock up when voltage is applied to the brown wire.
