mcfixstuff
- February 23, 2021
- Location
- Katy, TX
- Katy, Texas
- 1994 Explorer XLT 4WD A/T
No issues with my transmission for the last 2 years. I replaced the vacuum governor a year ago, and have had no issues. Recently, my truck has hated going 35mph. When I am driving 35mph, the transmission is trying with all its might to figure out what gear it wants to go into. 3.73 gearing if anyone asks. The transmission sometimes bounces between 3rd and 4th, and sometimes tries to drop into overdrive which will be about 900 rpm at that speed. Once it realizes it cant do O/D it pops back out. This makes the driving experience at 35mph extremely unpleasant as the car constantly jerks around while trying to find the gear. Putting it on D and not OD helps the issue a bit, but the rpm needle still bounces a little at that speed. No slippage during full throttle take offs, once I get below 30 or above 40, everything is perfectly fine. Is this a synchro? Do I need to adjust the governor? Do I need to change the worm gear to compensate for my 31" tires? What should I have for dinner tonight? Anyone else have this issuse?
Any help would be appreciated! I really don't wanna drop the transmission quite yet. It looks like it had already been done before I got it since the mounting bolts were loose and it was leaking fluid when I got it 2 years ago. The fluid has been changed twice since I got it. Every 12k miles I do it.
