1Bernie
- October 3, 2015
- Perth
- 2010 Ford Ranger
Hi everyone, I have a 2010 Ford Ranger XL, with a 3 Liter Diesel engine, and a manual gearbox.
I fully understand that 4 wheel drive, high or low range, should only be used when the vehicle is on a soft surface, sand or mud. If it is used on a hard surface, tar or concrete, the transmission binds up and locks the wheels due to slight differences in the rotational speeds of the wheels. This can very quickly result in broken components in the drive train, and an overheated, smoking clutch.
However, I am presently towing a 3 ton caravan around Australia, and occasionally, I get into situations where I need low range to manoeuvre the caravan into tricky parking spaces. If I use 2 wheel drive high range, I smoke the clutch from slipping it too much. If I use 4 wheel drive low range, the transmission binds up and I smoke the clutch because I cannot feel the difference between the weight of the caravan, and the transmission binding up.
So, what I would like to achieve, is being able to select low range, but without the front wheel drive engaging. I presume the front wheels are engaged electronically when the gearbox is shifted into 4 wheel drive. Could I interrupt this electronic signal with a switch? Would this stop the transmission from binding up? Would the transmission still work?
Any insight into this problem would be appreciated,
Thanks, Bernie.
Thanks, Bernie.
