Transmission Code P0760 | Ford Explorer Forums - Serious Explorations
jorge332655
miami Fl
2004 Explorer
I have a 2004 V6 flex fuel explorer. Bought it about 3 weeks ago. I didnt notice the bulb was removed for the check engine. Anyways I was driving to day and the transmission started slipping going into 3rd gear. I turned the car off and on and its running like it use to. It does take a while to shift holds the gears to about 3000 rpm. Needless to say I dont have much money since I just bought the car. I bought a code scanner to try to figure this out I got a Code 0760. Any help would be greatly appreciated. Thanks in advance.
that code comes up as "shift solenoid C malfunction"
P0760: Condition: SSC circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic.
Symptom: Open or short to battery power: second and fifth gear ratio incorrect. Short to ground: first gear ratio incorrect or no gear ratio errors. May turn on MIL light.
Repair procedure: Use voltmeter and ohmmeter to carry out shift solenoid electrical condition. imp
Thanks for your help guys. Does anyone have instructions on how to do this? I appreciate you guys taking the time to help.
The entire test procedure is in my Ford Shop Manual. To post it here, with my dial-up internet service would take the rest of my evening, just can't do it.
If you can lay hands on a Ford Shop Manual, check it out. Consider buying one, they are all over ebay.. imp
