jsour
- May 7, 2002
- Upstate, NY
- 2007 EB 4.6 V8
Hello,
I just changed the radiator in my 2007 Ford Explorer EB with 4.6 V-8.
My question is regarding the transmission cooler lines that connect to the bottom of the radiator.
The original ford connector appears to be different then the connector on my new radiator.
The first picture is the OEM connector.
https://picasaweb.google.com/110050057968075642385/FordExplorer?authkey=Gv1sRgCMij8IKAjMnpfg
The second picture is the connector that came with my new radiator.
Will the transmission coolant line fit/lock into the new connector?
Next question:
What is the part number of the tool to remove the old OEM fitting?
Reading through the forums I've seen three different tools referenced, OTC 307-569, OTC 6593 and Lisle LIS39960.
I went to Advanced Auto and Napa and was not able to find the correct tool that would fit over the Flare in the cooler line that's near the fitting?
Thank you for the help!
Next question:
