- December 16, 2010
- Greer, SC
- 2001 SAS'd Sport Trac
Due to my SAS and having a LP front axle I need to make a new transmission crossmember. I want to have dual 2" tube with a plate in the middle that bolts to the transmission. Problem is the tube bender is limited to 1/8" wall thickness. Would it be better to go with say dual 2x2 square with a 3/16" wall and use mitered corners instead or maybe several angles to get a "bend"?
This is sort of what I'm going for. And any ideas or criticisms are welcome. I'm just getting into fab work so not the brightest in this area.
