Transmission dipstick & manifold bolt size are needed.
hudson52
1994 Explorer
This past weekend I had the "pleasure" of replacing the coil pack in my 1994 4.0 Aerostar. The only way I could find to remove the old pack out through the tunnel cover opening was to remove the bolt holding the transmission dipstick tube and vacuum line to the manifold so they could be moved over to make room.
Since the location of the bolt is so difficult to reach it slipped from my grasp when trying to bolt the tubes back to the manifold, falling to God-knows-where never to be seen again.
Does anyone know what size this bolt is so I may locate a replacement? I've done quite a bit of searching but to no avail. Thanks.
92exp4x4
Covington, Kentucky
92 XL 2-door and others
I think its 6 x 1.25 mm, not sure though.
hudson52
1994 Explorer
That sounds reasonable based on what it looked like, so at least I have a starting point. Thanks!
Sip
Location
Houston
Texas
Ford Explorer 91
Hi do you know where the transmission bolt is located on the Ford Explorer 91? Like did you find the bolt size and can you take a picture where it is mounted too. I’ve been looking to and I can’t find it.
Sip
Location
Houston
Texas
Ford Explorer 91
I’m looking for the bolt size too for the transmission oil dipstick. Is this the correct size above? Also, do you know where it’s mounted at so my oil dipstick don’t be shaking around?
