Transmission Drain Plug Question? | Ford Explorer - Ford Ranger Forums - Serious Explorations
jkexplorer
San Francisco, CA
2000 XLT
I was searching for a transmission drain plug, and was wondering if anyone used a Fumoto engine oil valve for their transmission pan? Seems to me that it should work with the addition of a nut on the inside of the pan. Perhaps there are some inherent problems in this that I cannot visualize. I did find one other drain plug from Kragen's Auto Supply. The drain plug was Mr. Gasket, part No. 4470. Any comments on either item or other recommendations would be appreciated.
Glacier991
EF Tranny Guru
Moderator Emeritus
Sacramento, CA 95827
1992 XLT
see my answer to your post in the 5R55 post above.
jkexplorer
San Francisco, CA
2000 XLT
Thank you for the information!!!
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
just get one from autozone
jkexplorer
San Francisco, CA
2000 XLT
I could not find one on the Autozone website, but found one at Kragen's. I'll probably purchase it there. Thanks...
spindlecone
San Jose, Calif
2003 sport trac
The Kragen plugs work great, I used RTV on mine and never had a leak, but every time I pulled the plug I got nervous about the inner nut and breaking the seal.
A fumoto would be great but major overkill IMO.
It would be cake to braze a brass insert into the OEM pan with a plug, may be a better way.
I run an oversize PML pan now with a huge drainplug, no worrys
