patternfall
- June 20, 2010
- Seattle, WA
- 1990 XLT
1993 Explorer 4x4 XLT w/ M5OD manual transmission
Driving down the highway and suddenly 5th gear drops out like it's in neutral. Switch to 4th and it drives. Further testing shows Reverse, 1st, 2nd, 3rd, and 5th gears are all not engaging. The shifter moves, it feels like it "engages" with a little bit of expected resistance, but alas no power.
I ended up driving from Oregon to Seattle - 190 miles - in just 4th gear. Actually made it in the driveway, too.
So I've researched that 4th gear is direct drive 1:1, which I am guessing is the reason it kept working... but I know very little about transmissions, unfortunately. I've started looking around the area for a cheap replacement, but I wanted to make sure this is a major problem that can't easily be repaired.
Any thoughts?
Any thoughts?
