RonParise
- December 5, 2019
- Ft Myers Fl
- 2011 Explorer limited
When I did a preemptive replacement of the water pump on my 2011 Limited. I decided to keep this thing forever. Im no car guy, so all I know in terms of required maintenance is what's in the owners manual. and Im learning that that's probably not a good thing, given the fact that there is nothing in the owners manual about the water pump issue
Regarding the transmission.
Per the owners manual, I had transmission service done at 150000 miles Im at 300000 miles now, and I learned that all that was done at 150000 miles was a drain and fill, which means only 4 quarts have been replaced in 300000 miles. And Im also learning that service every 150000 miles is probably not enough.
So heres what Im doing.. Im in the middle of replacing all the oil, 4 quarts at a time. At each oil change, Im draining 4 quarts out of the transmission and adding 4 quarts,,,, Which brings me to my questions.
I know that the transmission filter cant be changed, Which makes no sense to me at all. I mean, why have a filter to catch contaminants if it cant be changed? What happens if the filter becomes clogged, is the flow of oil impeded. or is there a bypass? And my big question: does it make sense to add an external filter?
