jseen
- May 3, 2022
- Norman
- 2007 Sport Trac Limited
I just changed the transmission fluid for my 07 sport Trac with a 6r60 trans.
When under the truck, I noticed the pan was was quite a bit more shallow than I'd seen from others doing a fluid change on this transmission.
I emptied about 6.5 qts. And was only able to pump in 5.5 qts before it started overflowing. I shifted gears, took it out a bit to get the fluid all over. Then tried to pump more in. Still overflowing.
I'm worried that it's over filled, but this is definitely less than what was in it previous. Not sure what to do. Transmission shifts and feels great though
