Transmission fluid level How to check
AdrenalineJunky
Location
Northeast
Nh
2020 explorer ST.
Has anyone looked into it And what is the procedure. Ty
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
According to the Owner's Manual, this procedure has to be done by the dealer. There is no dipstick.
Will3
2020 Explorer ST
Here's a picture of the ST transmission. The dipstick is under the orange plug shown on the driver's side of the transmission case. Most owners aren't going to be interested in going under their Explorer to check the transmission fluid level, ergo Peter's post.
AdrenalineJunky
Location
Northeast
Nh
2020 explorer ST.
Check while running or not? I assume there is a warm and cold level on some sort of mini dipstick there under that cap.....
Will3
2020 Explorer ST
Here's a picture of what it looks like although this isn't the exact part. Can't help you on the proper procedure for checking. :dunno:
AdrenalineJunky
Location
Northeast
Nh
2020 explorer ST.
From what I gathered. Check when trans is at normal operating temp. While running. Small capped dipstick on Pass side, set fluid to the B level. Highly recommend to do on a lift.
northvibe
2020 Ford Explorer XLT
I'm very interested in the trans, ptu and rear diff oil check and replace. On the 15' escape they under filled all from the factory. So you'd get some odd behavior early on.
