Cryosong
- November 3, 2019
- Location
- Charleston, SC
- Charleston, SC
- 2000 Explorer xlt 4.0 OHV
Last night I decided to change the trans fliter and fluid. I bought 5qts of Valvoline MaxLife since it was on sale and saw others use it over Mercon V with positive results. I guess there was less fluid then I thought since the 5qts wasn't enough, and since it was late and I still needed to drive home, I stopped at Walmart to get a qt. Didnt have any mercon V so I opted with supertech mercon lv/dexcon vi, half way thru the bottle I noticed the words "Not Recommended for use with Mercon V" I stopped pouring it immediately, and checked fluid level and it is only at the very bottom dot. With the many mixxed answers I've found online, I wanna assume that if I top it the rest of the way off with the correct stuff it'll be fine and I'm probably over thinking it, but being my only transportation to work, and knowing how temperamental transmissions can be I wanna be sure. Should I just go ahead and eat the 5qts and drain and refill? Maybe add some Lucas Transmission conditioner? Thanks for any input you guys have.
