WillieTD
- June 19, 2003
- Lithuania
The dipstick says "Mercon V" (for a 4R70W). This sucks, because the cheapest I found it is $2.89/qt at Autozone. Anyhow, how many quarts do I ACTUALLY need? See, I'm not doing a flush, only installing a shift kit, so I'm assuming all of the fluid won't drain out. Do actually need to buy 13 quarts, which is the max fluid capacity?
BTW, my owners manual says Mercon in one spot and Mercon V in the other. That would be pretty confusing for someone that didn't check the dipstick.
