foxracr
- March 26, 2007
- Bloomington, IN
- 2004 Ranger
Hi I've got a 2006 explorer 4.0l that I cannot figure out what to do next. So it wont shift without giving it gas or waiting like 10 seconds. It has a hard time shifting up, it will just slip and slam into gear. I ran my code scanner on it and got a p0750 and p0760 shift solenoid codes. I went ahead and dropped the pan and replaced the shift solenoid block. There was a few small flakes of metal in the pan and the transmission fluid is burnt. I put it all back together and its still throwing the same codes and still not working, hesitant reverse gear and slipping drive gears. At this point I dont know what to do next. I also couldn't get the bulkhead connector to tighten down to the solenoid pack, it might be plugged in but doesnt seem like it will tighten all the way, might have stripped it whoops. I dont know what codes would be thrown if it wasnt connected properly? Any advice would be really appreciated!
