Transmission jolt when shifting into reverse | Ford Explorer - Ford Ranger Forums - Serious Explorations
jjcast13
My 2006 XLT Explorer will have a jolt when shifting from drive to reverse. It is occassional yet happens more often than not. When shifting into reverse there is a slight delay and then a jolt when the gear engages. Any suggestions as to the cause or remedy?
Davidm53
Broken Arrow, Oklahoma
2016 Ford Explorer XLT
My 06, will "jolt" sometimes when in park going to reverse. Figure it's a 4WD thing, I am new to this setup.
It might be while the idle air control has the rpms above normal idle.
1AJeremyD
Mass
95 XLT 4.0
Any and all jolts are pretty much related back to the vehicles transmission. If you have an extreme jolt in any gear at all it has to do with the transmission not working properly. Most likely you are not familiar with the quirks of the vehicle so I would suggest you bring it to a transmission shop.
brockdog08
Dallas, TX
2006 Mountaineer
My Mountaineer did this at 41k miles, there was a solenoid bad in the tranny, Ford did a rebuild. Been working great ever since. Would have run me $1500.00 if not for my 100k mile powertrain warranty.
Ronin8002
Virginia
2008 XLT Ironman
sidney12345
CBS, Newfoundland
2006 explorer,2009 Jetta
I know theres a TSB from ford on irratic transmission shifts. Reprogram fixes it
mtnexplorer06
Raleigh, NC
06 Eddie Bauer
I'm having a similar issue as well. Whenever I come to a dead stop from anything over 45 MPH, the transmission skips first gear on the downshift range and goes in to neutral. Then, the tranny waits 15-30 seconds before engaging back in to first. Sometimes if you're waiting to begin moving again after it does the neutral shift it will rev up to 3000 rpms before engaging - then you get a whole vehicle jolt before it finally starts rolling again.
wingley
kelowna, b.c.
2002 xlt
Try reprogramming the PCM(Dealer - $100 in Canada) if that does not work you would have to take a shot at replacing the SOLENOID Pack(Dealer 500 plus Labor, Pack can be purchased on Ebay for less than 300)
brockdog08
Dallas, TX
2006 Mountaineer
My Mountaineer is back in the shop, buzzing noise when started, goes away after warm up. Only makes the noise when the temps outside cool down. Dealer is replacing the torque converter, a pump and a part associated with the OD. Thank goodness again for the 100K warranty.
nh5
Long Island
'06 Explorer XLT V6
eBay solenoid pack, picked it up for $255 on ebay. Had it installed yesterday and its all fixed, shifts like brand new. Was slamming into reverse and had delays and jittering like it was losing pressure when shifting up
mtnexplorer06
Raleigh, NC
06 Eddie Bauer
brockdog was about right on this one - After 2 weeks in the shop, one loaner vehicle, and one warranty claim - the dealer replaced the Torque Converter, the Solenoid Pack and rebuilt the Trans. Apparently, metal shards were shearing off inside the TC and passing through the Valve Body and Flow Valve, and because there was so much metal passing through the TC and in to the Trans, the Trans had to be rebuilt. Thanks for all who put suggestions out there, because this thread really helped!
Orleans
2005 Ford Explore Limited
rdlsz24
Northern IL
2006 Mountaineer V6 AWD
My wife's 06 AWD V6 Mountaineer is having the slamming into reverse issue, and sometimes stumbling/shifting hard on upshifts on the highway. It has 85k miles. I have been changing the fluid and filter every 30k miles like I do on all three of our vehicles.
It doesn't have any check engine light. Is it possible for this solenoid to be bad without a light?
Rob
rdlsz24
Northern IL
I bought one for a decent price and am installing it today so we will see if it makes a difference
Rob
rdlsz24
Northern IL
After a few drives on the highway it seems that our issue is indeed gone. My wife is impressed with my car fixing skills. Thanks to the members of this forum for the info
Rob
fowlwater1
hayward wi
00' explorer
so will this same solenoid pack the link is for to ebay also fit my 2000 explorer?
