Maryk
- May 12, 2015
- St Pete
- 1996 Explorer
Hi Every One!
I am the new owner of a 1996 Explorer V8. After driving a few days the trans started slipping. We found a transmission fluid leak. I have changed the pan gasket and filter. Tightened/torqued the bolts. Changed and replaced the o-ring on the VSS.
After 3 hours of searching/wiping/flashlight/ test driving/ wiping/searching etc..etc... I am convinced that the leak is coming from the junction of the transmission body and extension.
QUESTION....
Can I change the gasket between the tran and the extension without dropping the whole transmission?
The transmission runs perfectly as long as the fluid is topped off so I am keeping close watch on it until repair can be made.
I am a beginner so please give as much detail as you can if you are able to reply. I bought a Chilton which is a great resource but this is not covered.
Thank you!
QUESTION....
Thank you!
