FLRN
- September 30, 2012
- NE Florida
- 2006 Eddie Bauer Explorer
Several weeks ago 2006 Ford Explorer Eddie Bauer Edition started acting as if it was running over rumble strips - a vibration that appeared to be coming from the back end. But then we noticed that the RPM's would give a little bump up each time this happened. Took it to a friend's highly recommended mechanic, and they said it was the torque converter, which they replaced with OEM ($750). They also performed a "reflash". (we also had the rear end checked just in case, and it was ok - engine was put on computer and showed no errors, etc.)
When I picked it up, it seemed to shift much smoother between gears (it had shifted very roughly) but it was still doing the little RPM bumps. Took it back and they said they thought it needed a new valve body. That was going to be $1500 just for the part, and they were going to do the install at N/C since they had assured us the TQ would fix the issue.
We had them hold off, and took it to AAMCO (this particular one again recommended by another friend) and they did a diagnostic at N/C. They just called and said the transmission is fine, and they see nothing wrong with it. I did notice today on the trip there it only happened a couple of times, and it may have been normal but I'm just overly concerned about it.
Unsure what else we might be looking at. We pull a pretty heavy trailer with this, and it's coming up on camping season. We just had to have the radiator replaced, to the tune of $800, and the TQ, so would really like for it to be nothing. Could the fluids just have needed more time to work themselves through and it's now ok?
Any ideas welcomed. Probably obvious from my post that we are not mechanically inclined in our house.
