transmission problem | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
greg92683
greg92683
I have a 94 explorer with manual 5 speed that seems to hang up between gears, Will shift fine when running but if I shift into nuetral at stop will often bind and not want to go into first.If I wait 5 secounds with clutch engaged it will slide in no prob. I was told there is a problem with the syncros being dirty and that this was a problem peculiar to the maza 5 speed.Tried adding a quart of gear oil and it helped but didn't fix the problem. Any suggestions would be appreciated
