this happened to my 96 a few months after I bought mine. I did the valve body plate replacement and replaced the EPC, 05/2014. It bought me a few weeks but one day it just stopped shifting past 2nd gear. Had the trans rebuilt 06/2014.
My original posting 2014:
4R55E trans issue
Thanks in advance for any answers anyone can give
Back story.
Bought used 2-3 months ago. Unknown history. 1996 Explorer EB, A/T, 4x4, 4.0 OHV, 134K miles. I had the 2-3 shift flare problem and then later, slow to engage reverse. Driving home one night my O/D light started flashing and it didn't seem to want to shift to 3rd. Playing with the throttle it finally shifted up and we got home. Started the next day. O/D flashing was gone and it seemed OK. Parked it.
Did some research on 4R55E/5R55E trans problems and decided to try the valve body separator plate.
Further research and decided to replace the electronic pressure control solenoid also.
Upon teardown, the VB seemed to be OK with no visible blown out areas. Replaced VB separator plate, EP solenoid, pan /filter, filled with Mercon V and 1 Lucas trans additive. Cleared codes, just in case, so computer was starting fresh after the work done.
Now trans shifts better but only under light throttle. Easing into the throttle the trans seems to shift fine with no flare issues. Problem is under heavier throttle, acceleration from a stop into faster moving traffic, the trans will not shift into, I think, 3rd and the O/D light starts flashing.
If I pull over and shut it off and restart it will shift fine, again under light throttle.
Scanned for codes but found none?
I am dropping it off at a shop to have them take a look/ test drive/ scan.
Any suggestions as to what I may be looking at? Solenoids, bands, servos???
http://www.explorerforum.com/forums/showthread.php?t=408017
