2017PIU
- October 17, 2024
- Huntsville Tx
- 2017 PIU
New guy here. Just bought a 2017 police explorer with the 3.5l Ecoboost. It had a broken shaft on the rear turbo, and in the course of changing it, pulled the right side stub shaft. I was under the impression that the axle stub was in the ptu, and at most I would loose something near 20oz of gear lube. However, out came considerably more fluid than that. In my panic, I slid my whole bucket of oil dry under the leak. It's hard to gauge how much came out, since it's now mixed with quite a bit of oil dry. But if I had to guess, it was near 2 quarts.
That leaves me with 2 possibilities, the ptu was massively overfilled, or the stub shaft rides in transmission fluid, not the gear lube of the ptu.
I did pull the drain plug after the fact, and the ptu oil is perfectly clean looking with no odor, leading me to believe that someone has been there before, and perhaps overfilled?
If I stick my finger in the stub shaft seal, the lube that I can touch doesn't smell like transmission fluid, and appears to be more gear lube colored.
Any comments?
Any comments?
