matt.t.copeland
- January 29, 2012
- Tennesse
- '99 ford explorer sport
Hellos, this is my first post and if a question that's already been asked(which i'm sure it has) I want to apologize in advance, but here goes....
Vehicle: '99 ford explorer sport, 2wheel drive,6 cylinder,automatic transmission,4.0,SOHC
Problem: after shifting into reverse heard a loud thump and then no more reverse, all other gears work fine, but when I shift into reverse it's like being in Neutral.
all the research I've done suggests it's either the reverse servo?....or the reverse band.I removed the drain pan and discovered small bits of metal, not cast though.I have since removed the transmission from the car to get a closer inspection. once I removed the four bolt that hold on the servo cover I noticed that there is no spring-action in the piston as it did not push the cover off when I removed the bolts, which leads me to believe that the pieces of metal I found in the pan were from the spring that is supposed to be there,though I cannot see it.
Question: How do I remove the servo?
