MikeyDog
- January 2, 2011
- Crestline. CA
Hi All!
Read a lot on here, NO Reverse on 96 Exp 4X4 4R55E?
135K miles and it look like former owner may have done the filter and oil at 85K?
Runs fine forward?
I put my laptop and USB code reader on and got P0751 and P0756
Shift Solonoid A performance or stuck off
also B?
How do A and B relate to SOL1, 2, 3 ect in transmission manual?
I have the pan off and wonder if I can clean these?
Should I try taking them down or out.
Are there O rings that need replacing.
Which ones are A and B?
Can I check them with an ohm meter to see if they are not open at this point.
Maybe stuck from sludge?
There was slime and goop in the pan.
HELP! I have never been here before.
My girl friends Explorer, and a trans cost more than the thing is worth!
Can I spray clean anything with a can of something?
Should I put an additive in.
I will put a filter and fluid in after cleaning and checking stuff you guys suggest! Then??? To a high priced expert?
Thanks! And thanks for the dowload of the transmission manual!
Great Group!
Mikey in Crestline Ca, nearly a mile high in the San Bernardino Mountains!
Runs fine forward?
also B?
Great Group!
