fireinsyde
- June 24, 2018
- 2007 Explorer XLT
I'm posting this solution to "pay it forward" for all the posts I've utilized in the past.
2007 Ford Explorer XLT with 4.6 L 3-valve engine, with 6R60 6-speed transmission.
Radiator was leaking a year ago, so I changed the radiator. Disconnecting the transmission lines to change the radiator meant that I had to top off the transmission fluid level when the job was done (a chore in and of itself in these trucks.) I did that.
Around that time, the truck began to "slip" or "lug" or "stutter" on the highway while in 5th or 6th gears only, and when accelerating between 50MPH and 70MPH. The problem was worse when climbing a hill, and went away completely if you either hit the gas hard to downshift the transmission, or when you shut off the OD, and caused the RPMs to rise that way.
No OBD codes were ever triggered.
After a lot of research, it seemed very similar to a "torque converter lockup shudder", and other transmission problems which are caused by incorrect fluid levels. These transmissions are VERY sensitive to improper levels, and can lead to slippage with as little as 1/2 quart underfilled or overfilled.
I spent a very long time alternating between a filler hose and a vacuum gun trying to get the transmission fluid to a perfect level (I used the correct motorcraft Mercon SP). What was DRIVING ME CRAZY was that each adjustment of transmission fluid in half-quart increments would change the nature of the slipping problem. It would improve slightly, or even by half, and then with another adjustment of fluid, would then get worse again. The fact that fluid adjustments led to changes in the slippage problem had me convinced beyond all doubt that the problem was the transmission. This coupled with the fact that I had drained the cooler lines to begin with.
The problem was not the transmission. It was spark plug misfire. After months of this, the truck FINALLY threw a P0300 code, and only after I revved it to 6,500RPM while passing on the highway.
Research showed that transmission slippage, torque converter shudder, and spark plug misfire all give a very similar feeling, and are mistaken for each other all the time.
I changed all 8 coils and plugs, and the problem is gone.
As for the confusing fact that the transmission level actually improved or worsened the problem...all I can figure is that the lower or higher fluid level affected the slippage in the converter, thereby putting greater or lesser load on the engine as I adjusted the fluid level, and it changed the conditions of the misfiring.
And it is the world's most incredible coincidence that the problem started right around the time I disconnected the transmission lines.
It was a tricky one. The moral of the story: if your transmission is slipping or lugging, consider changing your plugs and coils.
Good luck.
Good luck.
