Lucky178
- March 12, 2010
- Shiloh, IL
- 96 Explorer Sport 4X4
sorry to start things off with a problem. I have a 96 explorer and i am having a problem with the speedometer. when i push on the gas petal it works but when i let go of the gas the speedometer stops working. i have changed the vehicle speed sensor in the transmission and the abs speed sensor in the rear differential. my odometer seems to be working but I'm pretty sure its off. a full tank of gas only got me 140 miles. I'm pretty sure thats not right. i have a 4r55e transmission. i have had the o/d light flash on me a few times and the abs light came on. since i have changed to abs speed sensor these lights have not came back on. what im wondering is if my speedometer problem is a pressure problem in the transmission. when the o/d light came on the transmission began to shift very poorly. after the light went off everything was working good again. i have had the codes ran and i got 2 codes. one was for vehicle speed sensor and the other was catalytic converter. i am wondering if i should get a transmission flush done or should i change the valve body assembly in the transmission. Any help would be greatly appreciated. Thanks
