Scotts96sploder
- February 10, 2019
- Jacksonville FL
- 96 Explorer 5.0 rwd
I have dug through the forum, cannot find this.
I’m working on a one ton swap, starting with a 96 5.0 2wd. I can use my 4r70w if I can find the output shaft/tail house kit for 4wd, but they are sold out everywhere. I wanted to run an np205 but I can’t find an affordable one of those either. I have found that I could find a bw4406 in a 96-03 150/250, or 4407 96-98 250/350, which I believe were also 4r70w. So my question is, will the transmission out of one of those trucks bolt up to my 5.0? Im hoping to get lucky and find a trans/xfer case as a unit.
So thats where the rabbit hole starts of ford transmission codes ( mine is a PKF-AC) which I started reaseaching to see if I could find a chart for the codes in order to know what codes to look for that will swap. Dose this list exist?
My local yard only charges $100 for a trans, and $100 for an xfer case, doesn’t matter what it is, I’m kinda poor so if there is a way for me to pull this stuff that would be amazing, and if someone knows of what year, or motor(like the5.4), or specific code I’m after I would really appreciate the help.
P.S. whoever thought to make the post title a search is a Genius!
