cqdx73
- September 20, 2010
- Illinois
Hi
My name is Jerry
60 years young
6 kids
11 grandchildren
40 years Communication Tech for ATT
Ham radio operator - mostly morse code
I really like your forum
My wife has a 2002 4x4 Explorer 160000 miles that we bought new.
Having overdrive problems - stuttering at highway speed - that go away when I turn OD off.
Also some 2nd gear free reving.
I am told 2nd gear and OD are one derived from the other.
Codes PO735 & PO775 - 5th gear out of ratio & transmission pressure control solendid B.
A local transmission shop tells me that it has an internal fluid leak due to a Ford design error. Such that an actuator rod rubs on the transmission case, thus causing the leak and my OD problem. And that the only fix is to install a lower mileage used transmission for 2200 dollars.
Sounds a little far fetched to me.
So has anyone ever heard of this problem, or is this shop blowing smoke up my ears.
Thanks in advance.
Jerry
My name is Jerry
60 years young
6 kids
11 grandchildren
Thanks in advance.
Jerry
