EdmondsXLT
- April 16, 2018
- Edmonds, WA
- 2003 Explorer XLT 4.0 AWD
Hi all, I'm having shift issues on my '03 XLT V6. It's got just over 197k on it and recently started slow/slip shifting on 2-3 mainly, sometimes it just keeps revving past 4k then I'll lift the throttle and it shifts, or will be a rather hard shift when it finally goes and the O/D light will start flashing. It pulled a code P0745 which seems to indicate the solenoid is going out. I pulled one from a junkyard Explorer and swapped it in yesterday, filled the fluid back up, and reset the PCM as I've seen instructed. Driving around yesterday and today it seemed a little better but couldn't quite tell since it's relearning everything still, but this afternoon I got the same issues and the O/D light started flashing again. I know it was a risk to use a junkyard solenoid vs a new/reman unit, but at $20 vs $135+ it seemed a reasonable starting place.
Any thoughts on what to check/try next? It's still drivable as is and I want to replace it sooner than later, so don't want to put too much into a possible fix.
