00XLS
- January 13, 2004
- Frackville/State College PA
- Explorer 00 XLS
When driving home friday from state, my tranny was slipping pretty bad between the 2-3 shift, rev up to anywhere from 3200-4500 rpm. Most other shifts seems normal, except the passing gear that completely slips at times. I'm also getting a loud hum on start up in P, not sure if thats related. The OD lights flashes too but not all the time. Occasionally the entire thing will slip so bad, I can give it a lot of gas with not much movement. Thoughts?? Its under warrenty so it'll be going in this week. I recently put in a drain plug and changed the fluid as well.
