Transmission Won’t Move
dalton_explorer
Oregon
1996 Ford Explorer XLT
So in my 96 Explorer with the 4.0 4wd, I Tried putting it in every gear and it doesn’t budge, there is no check engine light on and it has 246k miles on it but I was wondering if there is a quick fix for it or I’ll need to find a transmission, and if I need one where would be the cheapest place to find one, thanks
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
What he said.....If the fluid gets too low it wont move
hjthaboss2020
Lampasas, Texas
99 explorer eddie bauer
did you ever get this figured out cause I'm having the same issue and yes my fluid level is good. I felt a pop right when the trans stopped working.
S Transmission wont shift into 2nd gear Transmissions & Transfer Cases 2
G transmission wont click into gear. Transmissions & Transfer Cases 29
J gear selector wont engage after transmission rebuild Transmissions & Transfer Cases 0
A 94 Mazda B4000 installed new transmission wont go into drive but will go into reverse Transmissions & Transfer Cases 3
C 2004 Ford Explorer transmission. Options? Transmissions & Transfer Cases 3
D Transmission issue? Transmissions & Transfer Cases 1
R 2014 Transmission Leak Transmissions & Transfer Cases 1
F Attempting to diagnose transmission issue Transmissions & Transfer Cases 4
I Damaged Transmission Case Transmissions & Transfer Cases 4
J 4.6L AWD New transmission not engaging Transmissions & Transfer Cases 11
I Transmission Issue, Possibly Servo Pins Transmissions & Transfer Cases 5
S Lost S/C bleeder screw inside transmission Transmissions & Transfer Cases 17
0 2007 Sport Trac 4x4 a really weird acting transmission Transmissions & Transfer Cases 13
N 5r55e Transmission ?Wiring Issues? Transmissions & Transfer Cases 4
D AJ1E Transmission servo kit - anyone? Transmissions & Transfer Cases 2
F Transmission problem Transmissions & Transfer Cases 1
T HELP 06 Explorer Transmission Issues Transmissions & Transfer Cases 1
C Solved New 5R55S. The transmission slips. Transmissions & Transfer Cases 6
A 08 Ford explorer limited transmission question Transmissions & Transfer Cases 0
J 2000 5r55e front transmission leak Transmissions & Transfer Cases 2
D 2002 Transmission Transmissions & Transfer Cases 1
R Will a transmission from a 4.6 ford explorer work in a 4.0 explorer? Transmissions & Transfer Cases 4
K Transmission, clutch or what??? Transmissions & Transfer Cases 1
E How to refill a transmission [serious but stupid question]? Transmissions & Transfer Cases 4
R Solved Multiple transmission codes after sitting in storage. Transmissions & Transfer Cases 12
T 6R60 transmission upgrade to a 6R80 or swap. Transmissions & Transfer Cases 7
W 2006 Explorer Transmission Removal - Top 2 bolts Transmissions & Transfer Cases 5
S Not sure if the transmission shop is trying to rip me off! Transmissions & Transfer Cases 13
W transmission won't shift Transmissions & Transfer Cases 1
E 08 4.6 v8 eddie after water in transmission Transmissions & Transfer Cases 3
W 02 Explorer Transmission Leak Transmissions & Transfer Cases 11
J 94 A4LD Transmission slipped out of gear and now won't go into any gear. Transmissions & Transfer Cases 4
E Transmission slip when shifting gears Transmissions & Transfer Cases 1
K 2000 ford ranger transmission problems Transmissions & Transfer Cases 11
08EddieCA transmission swap - 2008 AWD into a 2WD Transmissions & Transfer Cases 6
B Transmission dipstick stuck after Changing valvebody Transmissions & Transfer Cases 1
B 03 Sport Trac Transmission Problem Transmissions & Transfer Cases 4
vroomzoomboom transmission compatibility Transmissions & Transfer Cases 6
B 5R55E transmission codes Transmissions & Transfer Cases 2
T A 4R55E was change to 5R55E during a transmission swap. Transmissions & Transfer Cases 22
J Greetings - Transmission swap for 1994? Transmissions & Transfer Cases 4
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
O 4R55 transmission p0775 error AJ1E OD servo fix? Transmissions & Transfer Cases 3
C What years will Ford explorer 94 transmission interchange? Transmissions & Transfer Cases 1
allmyEXes What kind of transmission do I have in my 1997 Explorer? Transmissions & Transfer Cases 3
C 1996 Explorer. The transmission only changes gears when I ease off of the throttle pedal. Transmissions & Transfer Cases 4
G 99 XLT 4x4 4.0 transmission--thinking of buying this-advice Transmissions & Transfer Cases 4
B Odd transmission behavior Transmissions & Transfer Cases 0
S What are these transmission parts Transmissions & Transfer Cases 6
D Transmission to engine stand Transmissions & Transfer Cases 3
Similar threads
