Sorry
- March 20, 2016
- Western NY
- 02 Explorer xls
Hey guys. I came up with a crazy idea. I'm not sure if it will work or not. But if the sensors work as I'm hoping, it should work just fine.
I'm having a P0741 TCC unlocking issue that I've pretty much narrowed down to being my actual TCC. Solenoid seems fine. Resistance is in spec. TCC locks, but unlocks from slipping.
This code is thrown when one of two conditions is met. Each condition requires two criteria. 1) solenoid is unlocked and engine rpm = turbine output speed or 2 solenoid is locked and rpm>tos.
Does anyone know if the turbine speed sensor works the same way the crank sensor works. For instance, at 3000 rpm, are the crank sensor and the TSS sending the same signal? Are they just both 50hz (or any correlated signal)? Or are they different types of signals that the PCM would sort out?
From my understanding, they are both magnetic pulse senders.
My thought is... have the TCC Solenoid signal to power a relay that would switch between Crank Sensor and Turbine Speed Sensor. When the solenoid is not hot, TSS would be sent to the PCM as normal. But when the solenoid is powered, the relay would send crank sensor info to the PCM to make it think that the TSS is matching the rpm.
I know... it's not the right way. But I'm going to drive this transmission until it leaves me on the side of the road. I'm just trying to avoid tripping the OD Off light, which puts the PCM onto limp mode. I can deal with the few MPG of not having the TCC lock. I can't deal with a limping PCM
