Trim Removal...
hostile413
Pekin, Illinois
'96 E.B. AWD
i searched for a thread about removing the fender trim on a 96 e.b. with no luck, its the trim that goes from the fender along the rocker panels to the rear fender, it looks pretty simple to remove, but my question is after i remove it, are ther holes under the trim that will show?..thought i'd ask before i remove it
FreeWheelin4x4
York, PA
'95 XLT 4.0 OHV 3.55
On my 95 xlt there are holes.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Yes, lots of holes. Use a trim removal tool, or a screwdriver with rounded edges, not sharp. Sit down and use your hands and screwdriver to get behind the trim. Gently get your fingers and the tool behind the trim, while not scrstching the paint. Use your hands to create leverage against the fender, pulling outward behind the trim.
You will need to pull the trim from each connector, outward, one at a time. Good luck,
hostile413
Pekin, Illinois
'96 E.B. AWD
thanks for the info guys
