Trouble Code 157 MAF | Ford Explorer - Ford Ranger Forums - Serious Explorations
Harry P
Harleysville, PA
94 XLT 4x4
CEL came on last week, and idle became rough.
KOEO: Code 111 (No faults on KOEO). I only get one CM Code 157 (Mass Air Flow signal is/was low or grounded – MAF). No other codes.
I took it out. It appeared fine, not dirty. I cleaned it with spray solvent. Put it back in, no change. I still get CEL and rough idle, and no additional codes.
Ex has 177k miles and the MAF has never been replaced. I recall taking it out to clean it six or seven years ago to solve the same code then.
What’s the next step? Should I buy a new MAF?
Thanks, Harry
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Get a can of Mass Air Flow cleaner.
Harry P
Harleysville, PA
94 XLT 4x4
Yep. I cleaned it. What's the next logical step?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
check the output voltage
You can test the MAF sensor (MAFS) by backprobing the connector pins with straight pins and then measuring the outputs with a voltmeter at various engine speeds. From the code you can't tell if the MAFS output is low at idle or fast engine speeds. If the output is low at idle then your engine will run lean.
