trouble code 172 | Ford Explorer - Ford Ranger Forums - Serious Explorations
trouble code 172
98Rig
Stevens Point, WI
92 XLT
so i had a code pop up when i was driving, happens only when i get to normal operating temperature. i have cleared the code and it pops back up when i get to normal operating temp. it says o2 sensor reads lean, is it bad or should i be looking somewhere else for the problem?
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
If this is on the '98 in your profile, you might want to post this in the 2nd gen forum, where people are more familiar with the EEC-V/OBD-2 set-up.
Yes, the O2 sensor might be bad, or you might need to look elsewhere for the problem. That's part of why lean O2 codes can be so hard to diagnose: there are so many things that can trigger them.
By the book, you usually start diagnosing O2 sensor codes by checking fuel pressure. Definitely check the wiring between the sensor and the PCM. Also check for vacuum leaks.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
98Rig
Stevens Point, WI
92 XLT
its a 92 explorer
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
