minzamerc
- April 22, 2006
- Delafield, WI
- 02 XLT, 99 MOUNT.
My 2002 Explorer 4.0 L was missing and spewing what appears to be raw gas out the exhaust, with plenty of white smoke - coolant level was not down at all so I know it wasn't a head gasket or similar problem. My plugs have only 3,000 miles on them, so I tried a new coil, with no luck.
I removed the intake manifold and looked at the fuel injectors. The # 1 injector had a cracked tip, so I thought I had found the reason the #1 intake port was full to the top with fuel. I put it back together with new injectors and again, no change.
Does any one have a clue as to why the #1 intake port was full of gas? Is it possible the intake valve is not opening due to a broken rocker arm or valve?
Thanks to anyone who has an idea.
